EPoX 9NPA+SLI Mainboard Review 2/7
Bluetooth 28 Mar 2005
Benchmarks
Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs exactly at 200.9MHz.
The following readings are obtained using CPU-Z.
In the first test, we used a pair of TwinX Corsair RAM and runs it at CAS 2, 5-2-2, 1T timing. This board scored 6087/6039 (ALU/FPU). Although the memory controller is within the CPU, the higher the scores indicates the board's stability at aggressive timings.
