EPoX EP-8NPA SLi Mainboard Review 2/7
Bluetooth 13 Sep 2005
Benchmarks
Before you read on, do take note that EPoX EP-8NPA SLi is a Socket 754 running 3400+ (2.2GHz) with 1GB Corsair TWIN CAS 2, 5-2-2, 1Tcmd. The other boards in the benchmarks are benchmarked based on AMD FX-53 which is rated 2.4GHz.
Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs exactly at 200.9MHz.
The following readings are obtained using CPU-Z.
It should be apparent that S754 being Single channel memory will not give you what a dual channel memory scores. Will this affect the scores when we compare this board with 3400+ (S754) vs the others based on S939 using a FX53? Read on.
