ASrock 939A8X-M Mainboard
Review 2/7
Benchmarks Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs at 199.9MHz which is slightly below the expected 200.00. The following readings are obtained using CPU-Z. The ASrock 939A8X-M registers an exact 200.00MHz We used a pair of TwinX Corsair RAM and runs it at CAS 2, 5-2-2 and below are the memory benchmark scores obtained. Comparing the previous boards based on the same chipset, the 939A8X-M seems to score lower. This could be due to the higher FSB used on the reference board.
