Nebula Electronics
DigiTV USB (3)
From the image below, you can see the next in line programme. You can also check the programme descriptions. As the DVB-T broadcasts does not include digitext, we are unable to show it.
EPG for the day
Downloading 7 days EPG in progress
Something unique about the DigiTV is that it is not just a DVB Tuner but it could be used as a server. That means, you can actually multicast your Digital TV broadcasts to all the other PCs on the same subnet. Below is a screen shot of the menu which you could enable the machine as a DigiTV server. It also comes with a HTTP server which allows you to control and find out information of your USB device via a web interface.
The current broadcasts here is just 2 channels - left and right
