Press CTRL+F1
reveals the Advance Chipset Features. The options are comprehensive and we
are using F6 production bios which you can download from Gigabyte website.
We set the system to the above, CAS Latency
to 2, and we adjusted tRCD, tRAS and tRP to 2,5,2 respectively. |
At the bottom
of the screen, you can set the local frame buffer to 64M or you can use
the VGA share memory. Default it 0 and 64 respectively.
Graphics core Engine is default to 166MHz.
If you run at SPD, chances of running it at 200MHz is possible with
cooling of the NB. |
