Gigabyte 3D Rocket-Pro Cooler PCU22-VG (2)
Bluetooth 2 Aug 2004
Specs
Heatsink Dimension 105x105x119mm
Rated Voltage 6.3v ~12v
Rated Current 0.15A (0.5A Max.)
Fan Speed
  • 2500±10% rpm (Default)
  • 4000±10% rpm (With fan speed control cable)
  • Noise
  • 23.7dBA at 2500rpm
  • 37.2.5dBA at 4000rpm
  • Bearing Type Ball bearing
    Life Expectancy 70000Hr
    Total Weight 500 g
    Application
  • Intel® Pentium® 4 478 3.4GHz
  • AMD Athlon XP 3400+
  • AMD Athlon 64 3400+
  • Package Contents:
  • PCU22-VG
  • Heat sink paste Injector (ShinEtsu X-3-7762)
  • Intel® Pentium® 4 Clips
  • AMD Athlon XP Clip
  • AMD Athlon 64 Clip
  • LGA775 RM
  • Fan Speed Control Cable
  • Discuss
