Tcl (CAS
LATENCY is set to 2), Max memclk to AUTO.
Trp is set to 2 in our tests. |
Tras is set
to 5 in our tests. |
Trcd is set
to 2 in our test. |
System
performance can be set to FAST or NORMAL. There is FIX AGP to 66. This
allows the AGP and PCI to remain stable at 66 and 33 MHz irregardless of
the FSB set during overclocking. CPU Clock Ratio is also available for
adjustments. CPU Overclock in MHz can be raised to 250MHz.
Multipler : 8x ~ 20x
Chipset voltage can be adjusted up to 1.75v. |
AGP voltage
can be adjusted up to 1.8v |
DIMM Voltage
can be adjusted up to 2.8v |
CPU Voltage
is adjustable up to 1.70v |
