EPoX
5EPA+ i915P Socket 775 Mainboard (2)
Benchmarks Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the EPoX 5EGA+ runs at 200.5MHz while the 5EPA+ runs default at 200.9MHz which is 0.4MHz faster. We made a check on the memory benchmarks using SiSoft Sandra and it scored 4709/4699 versus 4692/4691. Although it is a small difference, the performance difference would be more apparent when we run some benchmarks. Next >>> |
