EPoX 4PDA5+ Intel 865PE/ICH4 P4 Mainboard Gallery (4)
Bluetooth 2 Apr 2004
The BIOS
DRAM Timing Selectable is set to Manual and Ram Timing adjusted to CAS 2, 5-2-2. We also enabled Agreeisve memory Mode and Enabled CPU BUS PARK, FAST CS, CPC function. CPU Clock/Speed can be adjusted up to 350MHz FSB. Memory Frequency can be set to run at a ratio of the CPU speed. e.g. 1:1, 5:4 etc.
AGP PCI/AGP lock can be set here. Default is 66 CPU voltage is adjustable upwards to +0.325V of default
AGP voltage can be adjusted up to +0.40v of default VDimm voltage can be adjusted up to +0.40v of default
Pricing of ECS Boards
