ECS 755-A2 (SiS755) Gallery/Preview (3)
Bluetooth 20 Jan 2004
The BIOS
The Advanced Chipset Features in the BIOS enables you to select the DRAM Configuration, Auto Configuration which you can select safe,normal,fast,turbo or ultra mode. The other options available are Fast Write, Aperture Size, AGP transfer rate and System BIOS cacheable option In our tests, we set it to Ultra mode.
The DRAM Configuration has lots of options. In our case, we set the HT to 16 bits at 800MHz, Max Memclk to 200 to run SYNC mode. The system is set to run at CAS 2, 5-2-2 (CAS Latency, tRAS, tRCD, tRP). We used the same setting on other K8 boards tested. CPU Clk which is the FSB can be selected up to 232MHz FSB. This is a bit limited but I think it could be possible to adjust the FSB through some other software means.
SiS 755 NB SiS 964 SB
Pricing of ECS Boards
