Advance Menu of the BIOS. On
this page are options available for adjusting the FSB, CoolnQuiet,
Multiplier, Voltage, Memory Clock, Burst Length, CAS/Ram timings. |
Multiplier can be set from
4x ~ 25x |
Processor Voltage can be set
from 0.80v ~ 1.55v, Memory Clock can be set to Sync 200MHz (DDR400) or
DDR333, DDR266 so that it runs async. to the CPU FSB.
RAM timings are adjustable. CAS Latency, TRCD, TRAS, TRP.
We set it to CAS 2,11-2-2 for our Socket 939 FX53 and CAS 2, 5-2-2 for
Socket 754 AXP3200+ |
In Chipset Settings, you can
set the share memory if you are using the on board AGP. Aperture size can
be set to 128M. Fast Write can be enabled. HT Speed up to Auto,
200,400,600,800MHz can be set and HT Width (8 or 16 bits) |
