ASrock K8Upgrade-1689 ULi M1689 Socket 754/939 Gallery 3/4
Bluetooth 19 Nov 2004
BIOS (I)
Advance Menu of the BIOS. On this page are options available for adjusting the FSB, CoolnQuiet, Multiplier, Voltage, Memory Clock, Burst Length, CAS/Ram timings.
CPU Host Frequency can be set up to 300MHz
Multiplier can be set from 4x ~ 25x
Processor Voltage can be set from 0.80v ~ 1.55v, Memory Clock can be set to Sync 200MHz (DDR400) or DDR333, DDR266 so that it runs async. to the CPU FSB. Memory Clk can be set to 133,166 or 200. Other options include Flexibility (for ram compatibility), Burst Length, Cas Latency.
RAM timings are adjustable. CAS Latency, TRCD, TRAS, TRP. We set it to CAS 2,11-2-2 for our Socket 939 FX53 and CAS 2, 5-2-2 for Socket 754 AXP3200+
HT Speed, Default is 800Mhz can be set to 1GHz
HT Width can be set to AUTO, 8 or 16 bits. When used with 939board, only AUTO and 8 bits are available.
Discuss in  Forum
Socket 754 Benchmarks or
Socket 939 Benchmarks
