ASrock K8S8X (SiS755) Review (1)
Bluetooth 25 Feb 2004
Introduction
*Notice : No part of this review is to be reproduced in any form, reposted, edited, translated into any languages without the prior permission of OCWorkbench.com*
Since its inception, ASrock has been making headlines in different regions for its cost/performance ratio. In Year 2003, we reviewed a number of ASrock boards and we are quite satisfied with its performance for its low price for entry level board.
In year 2004, ASrock again make waves by introducing their Athlon 64 board based on the SiS 755 chipset. As we know, SiS K7 chipsets were known for its stability and compatibility and its comparable to the bigger dual channel designs. Would the K8 chipset board be as good as the Ref board we reviewed before ? We will check it out.
At first glance, the ASrock K7S8X looks like another brand because of its deep blue colour. The board looks plain but is very clean. Paired with the SIS 755/964 chipset, the board supports 2 ports of SATA RAID 0/1 + 2 IDE channels making it very flexible in the choice of storage.
On top of that, this board comes with Boot Failure Guard. We tested it and it worked as mentioned in the specficiation. When we overclock it above certain FSB, it will not boot and the BFG takes over and asks if you want to reset to defaults by pressing F2.
The board comes with 6 channel audio supported using CMedia 9739 chipset. The rear panel has connectors for 1 x PS/2 keyboard & PS/2 mouse connectors 4 x USB ports, 1 x RJ45 LAN connector, 1 x Parallel port (LPT1), 1 x Serial port (COM1), 1 x Audio ports (Line-in, Line-out, Mic-in) and 6 USB ports.
Lets check out the gallery for more photos and BIOS features of this board.
Specifications
CPU
Socket 754 , supporting AMD latest 64-bit Athlon 64 CPU
Chipset SiS 755+964
Hybrid Booster CPU Frequency Stepless Control
ASRock U-COP
Boot Failure Guard (B.F.G)
Memory 2 x DDR DIMMs, DDR400/333/266
Slots 1 x AGP 8X/4X 1.5Volt
PCI 5 slots, PCI 2.2
VGA N/A
Audio  AC97 CODEC
5.1 Channel 3D
LAN 802.3u, 10/100 Ethernet LAN, WOL supported
Modem N/A
Connector Serial ATA - 2x SATA connectors, 1.5Gb/s, RAID 0,1,JBOD
SATA HDD HotPlug
IDE 2 x ATA 133/100/66/33
Floppy 1 connector
1 x SIR
ASROCK I/O PLUS Keyboard PS2 x1
Mouse PS2 x1
USB2.0 - 6 ports default on rear panel + 2 ports upgrade via
                 header
Serial 1
Parallel 1
LAN 1 x RJ45
Audio I/O Line In/Line Out/Mic.
ASRock U-COP ASRock Universal CPU Overheating Protection
Other Connector CPU/Chassis FAN connectors
20 pin ATX power connector
2xUSB2.0 headers
CD/AUX/ audio in
Front panel audio connector
BIOS Feature 2Mb AMI BIOS with ACPI, SM BIOS 2.3.1, PnP
Manageability WOL,WOR
Support CD Drivers,
PC-cillin 2002,
ASRock PC DIY Live Demo,
Audio Player, etc..
Accessories Multi-languages Quick Installation Guide
Support CD
Floppy/ATA 100 cables
SATA cable Pack
   Serial ATA cable x 1
   Serial ATA 1-to-1 power cable x1
Form Factor ATX
