ASrock K7S41 (SiS 741) Gallery/Preview
(2) Bluetooth 3 Mar 2004
The Mainboard
Finished in blue, this MicroATX looks cool
inside cases. Although it is a MicroATX mainboard which only has 2 PCI slots and
1 AGP slot, 1 AMR, it is surprisingly that this board comes with a multiplier
(jumper) control and there is voltage adjustments for Vcore and Vdimm inside the
BIOS. The board comes with a silvered colour heatsink for the SiS 741 chipset .
2 PCI slots,
1 AGP 8x Slot, 1 AMR slot. On the mainboard is the audio codec CMedia 9739A
2 DIMM slots
supporting up to 2GB of DDR400. Socket A. This board uses a 2 phase
regulator. It might be a good idea to use a better PSU.
Floppy
Connector, SiS 963L South Bridge.
The power
connector connectors with 2 channels of IDE. There is no +12v connector..
The back
panel with PS/2 Keyboard,Mouse connector. 1 COM port. 1 Parallel port. 4
USB, 1 Ethernet 10/100Mbps LAN and 5.1 channel audio ports.
The ClkGen
responsible for the large range of FSB to 248MHz
SiS 741 North
Bridge with Integrated Real256 Video
