ASrock K7S41 (SiS 741) Review (1)
Bluetooth 3 Mar 2004
Introduction
*Notice : No part of this review is to be reproduced in any form, reposted, edited, translated into any languages without the prior permission of OCWorkbench.com*
The K7S8X series has been a success in the past. This year, ASrock releases another K7 board based on the SiS chipset. This new board K7S41 is based on SiS 741 chipset which is an upgrade of the previous integrated chipset SIS 740. SiS 741 official supports DDR400 and 400FSB CPU e.g. AXP 3200+.  With its Real256 onboard video, this chipset targets the low cost market. If you remember the SiS 315, that is what you would expect from the 2D and low 3D performance from this integrated graphics chipset.
Although this is a mATX board, it is a surprise that there are voltage adjustments for Vcore and Vdimm via BIOS and multiplier control using jumpers. There are also settings in the BIOS to overclock the 3D engine clk up to 200. FSB adjustments is up to 248MHz.
The board comes with 6 channel audio supported using CMedia 9739 chipset. The rear panel has connectors for 1 x PS/2 keyboard & PS/2 mouse connectors 4 x USB ports, 1 x RJ45 LAN connector, 1 x Parallel port (LPT1), 1 x Serial port (COM1), 1 x Audio ports (Line-in, Line-out, Mic-in) and 3 USB ports.
Lets check out the gallery for more photos and BIOS features of this board.
Specifications
CPU
Socket 462 , supporting AMD Athlon, Athlon XP, Duron
FSB 400/333/266/200 MHz
Chipset SiS 741+963L
Hybrid Booster CPU Frequency Stepless control
CPU Multiplier
CPU Vcore adjustment
ASRock U-COP
Boot Failure Guard
Memory Max. 2GB DDR
2 x DDR DIMM
DDR400/
333/266
Slots AGP 8X/4X 1.5V
PCI 2 slots, PCI 2.2
AMR 1
VGA Integrated Real 256E 3D Graphics
Memory Max. 64MB
Audio  AC97 CODEC
5.1 CH Audio
LAN 802.3u, 10/100 Ethernet LAN, WOL supported
Modem (optional) ( MR card optional )
Connector IDE 2 x ATA 133/100/66/33
Floppy 1 connector
SIR/CIR 1/0
ASROCK I/O  Keyboard PS2 x1
Mouse PS2 x1
USB2.0 4 ports default on rear panel + 2 ports upgrade via header
Serial 1COM port bracket
Parallel 1
Game/MIDI 1
LAN 1 x RJ45
Audio I/O Line In/Line Out/Mic.
VGA 1
ASRock U-COP ASRock Universal CPU Overheating Protection
Other Connector CPU/Chassis FAN connectors
20 pin ATX power connector
CD/AUX/ audio in
Front panel audio connector
BIOS Feature 2Mb AMI BIOS with ACPI, SM BIOS 2.3.1, PnP
Manageability WOL,WOR
Support CD Drivers,
Bundle CD includes:
PC-cillin 2002,
ASRock PC DIY Live Demo,
Audio Player, etc..
Accessories Multi-languages Quick Installation Guide,
Support CD,
Floppy/ATA 133/100 cables,
1x COM port bracket
Form Factor MicroATX
