SiS 648FX Ref Mainboard Review (1)
Bluetooth
23 May 2003
Last week, we saw the new Intel Springdale (i865PE) chipset which uses Dual DDR 400 technology supporting the latest Pentium 4 HT processors - 2.4C, 2.6C, 2.8C, 3.0C 800Mhz Pentium 4 CPUs. SiS is quick to react with the SiS 648FX chipset. SiS 648FX, though single channel DDR400 technology, results are very impressive compared to the Springdale Dual DDR400 chipset.
SiS 648FX comes with the new proprietary Hyperstreaming Technology which is optimised for
  • “Low Latency” with Single stream
  • “Pipelining” and “Concurrent Execution” with Multiple streams
  • “Prioritized Channel” with Specific stream
  • “Smart flow control” and “Intelligent arbitration” with Smart stream
You can read more about the technology at this SiS website.
This new technology avoids many of the out-of-sync audio, jittery images, low frame rates and possible packet transfer errors. With this new technology, it makes single channel as good as a dual channel design.
This SiS 648FX ref board comes with SiS180 controller. The SiS180 Serial ATA Host controller support two Independent Ports of Serial ATA 150, support Dual IDE Channels with Parallel ATA 133/100/66, PCI Rev 2.3, Software RAID Function - RAID0, RAID1, RAID0+1 and JBOD Function.
The SiS 180 controller can be set to work in two modes : Compatibility Mode and Native mode
In Compatibility mode, With Win98/WinMe OS Default IDE driver
Option 1: Disable 2 PATA Controller in 963L
and use 2S1P in 180 (Max. 4 devices)
Option 2: Disable 2S1P controller in 180 and
use 2 PATA controller in 963L
(Max. 4 devices)
In Native Mode, Native mode support OS
- Both 2 PATA controllers in 963L and
2S1P controllers in 180 can be enabled
• Maximum Support 8 IDE devices
• Native mode support OS is Win2K/WinXP and
Windows.Net Server
The best is native mode since you can hook up to 4 IDE devices to the PATA interface supported by SiS 963L. You can also hook up 2 SATA and 2 HD to the IDE3 and SATA ports (both supported by the SiS 180 chipset). This means that a maximum of 2 SATA and 6 HDD drives can be connected to the board. The interesting thing is that Software RAID function allows you to mix and match SATA and PATA in a RAID 0,1,0+1, JBOD array.
SiS648FX/963L/180
HSE, FSB800, DDR400 Plus AGP8X Chipset for Intel PentiumR 4 HT Platform
Specification
SiS648FX
 Host Interface Controller
- Support Intel PentiumR 4 HT 800 CPU
- Support Intel Hyper-Threading Technology
- Support 800/533/400MHz Front-Side Bus
 Integrated High Performance Dual Memory Controller
- Up to 2 DIMMs of DDR400, up to 3 DIMMs of DDR333/DDR266
- Support Un-buffered DDR DIMM and up to 1GB per DIMM
- Suspend-to-RAM(STR)
 Support AGP 8X Interface
- Support AGP 8X/4X Interface
- Support Enhancements of AGP v3.5 Register Format
- Support Fast Write Transaction
 MuTIOL 1GR Delivering 1GB/s Bandwidth
- Proprietary Interconnect between SiS648FX and SiS963L
- Bi-Directional 16-bit Data Bus at 533MHz Operating Frequency
SiS963L MuTIOL 1GR Media I/O
 USB 2.0/1.1 Host Controller
- One EHCI USB 2.0 Controller and 2 OHCI USB 1.1 Controllers
- Support Total 6 USB 2.0/1.1 Ports
- Support USB 2.0 High-Speed Device @480 Mb/s Transfer Rates
 Fast Ethernet/Home Networking Controller with MII Interface
- Support 10/100Mb Fast Ethernet or 1/10Mb HomePNA 2.0 with
External PHY
 Audio/Modem Controllers with AC’97 Interface
- AC’97 v2.2 Compliant
- Support 6 Channels of AC’97 Speakers Out and v.90 HSP Modem
 Advanced Power Management
- ACPI 1.0b and APM 1.2 Compliant
 Support Up to 6 PCI Masters
 LPC 1.0 Interface
 Integrated RTC
 Integrated Keyboard/PS2 Mouse Controller
 PC2001 Compliant
SiS180 Serial ATA Host Controller
 Support Two Independent Ports of Serial ATA 150
 Support Dual IDE Channels with Parallel ATA 133/100/66
 Support PCI Rev 2.3
 Software RAID Function Support
- Support RAID0, RAID1, RAID0+1 and JBOD Function
