Gigabyte 7VAXP-A Ultra KT400A (1)
Overclocker 23 Mar 2003
Continuing the success of the 7VAXP KT400 board, Gigabyte launches The KT400A 7VAXP-A Ultra based on the VIA KT400A chipset. Gigabyte 7VAXP-A Ultra is definitely one of the top "all-in-one" board that would appeal to those who loves technology. With Promise 20276 chip, the GA-7VAXP-A Ultra provides not only RAID 0(Striping) or RAID 1(Mirroring) function, but also additional two UDMA ATA-133/100 connectors, which allows users to connect total 8 ATAPI devices such as CD-ROM, CD/RW, DVD-ROM and DVD-RAM. The GA-7VAXP-A Ultra comes with 6 USB 2.0 ports at high data transfer rate up to 480Mbps, which is 40 times faster than the previous USB 1.1. With the SiliconImage controller chip, you can hook up another two more SATA HD to the system
In addition, the GA-7VAXP-A Ultra supports 3 IEEE1394 ports to enhance PC connectivity for consumer electronics audio/video (A/V) appliances, storage peripherals, other PCs, and portable devices. In addition to the usual boot devices, also supports boot up from USB devices such as CD-ROM, DVD-ROM, and ZIP drive. Interrupts can be assigned freely to each PCI device to meet individual needs.
The Gigabyte 7VAXP-A supports DDR400 providing system bus up to 6.4GB/sec, which is available with 3 DIMM slots supporting up to 3GB by DDR400+/333/266 memory module. The ALC650 incorporates proprietary converter technology to achieve a high SNR, greater than 90 dB. GA-7VAXP-A Ultra total support ALC650 AC’97 CODEC provides multiple CODEC extensions with independent variable sampling rates and built-in 3D effects.
Overclocking features include multiplier control via dip switch, FSB can be adjusted to 250Mhz, DIMM, AGP, Vcore voltages are all adjustable within BIOS. Other features that are available include Patented Dual BIOS™ technology, Easy Tune 4™, Q-Flash™ (Dual BIOS™ Utility), @BIOS™ and Face Wizard™.
GA-7VAXP-A Ultra
VIA KT400A chipset
Processor
  1. Socket A for AMD Athlon™ XP / Athlon™ /Duron™ processor
Chipset
  1. Northbridge : VIA KT400A
  2. Southbridge : VIA 8235
  3. VIA VT6306 IEEE1394 controller
  4. Super I/O : ITE IT8705F
  5. Silicon Image sil3112A controller
  6. Raeltek 8100BL Ethernet 10/100Mb LAN controller
  7. AC97 Realtek ALC650 6-channel sound Chip
  8. Dual BIOS
Front Side Bus
  1. 333/266/200 MHz FSB
Memory
  1. Type : DDR400(PC3200)/ DDR333 (PC2700) / DDR266 (PC2100) /DDR200 (PC1600) -184pin
  2. Max capacity : Up to 3GB by 3 DIMM slots
Internal I/O Connectors
  1. 1 x FDD port
  2. 4 x UDMA ATA133/100/66 Bus Master IDE ports
  3. 3 x IEEE 1394 connectors
  4. 2 x 2ports USB 2.0 connector (by cable)
  5. 2 x SATA connectors
  6. 3 x cooling fan pin header
Expansion Slots
  1. 1 x AGP universal slot (8X/4X/2X-AGP 3.0 compliant)
  2. 5 x PCI slots (PCI 2.2 compliant)
Rear Panel I/O
  1. PS/2 Keyboard / Mouse
  2. 2 x USB 2.0 ports
  3. 2 x COM ports
  4. 1 x RJ45 LAN port
  5. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
  6. 1 x GAME/ MIDI port
CPU/AGP/DIMM setting
  1. CPU FSB adjustable via BIOS (1MHz-linear)
  2. CPU multiplier by DIP Switch
  3. CPU Vcore Voltage adjustable via BIOS
  4. AGP Voltage / Clock adjustable via BIOS
  5. DIMM Voltage / Clock adjustable via BIOS
Form Factor
  1. ATX, Dimension : ( 30.5 x 24.4 cm )
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. H/W detect and report power-in voltage, CPU voltage, and Fan Speed Support auto detect temperature thermal shutdown function
Other Features
  1. GIGABYTE patented DualBIOS™
  2. IDE #1-#4, SCSI, LS120, ZIP, CD-ROM and USB bootable.
  3. Suspend to RAM (STR)
  4. Supports USB KB / MS wake up from S3
Bundle Software
  1. Norton Internet Security™
    1. Norton Anti Virus™
    2. Norton™ Personal Firewall
    3. Norton™ Privacy Control
    4. Norton™ Parental Control
    5. Ad Blocking
  2. GIGABYTE Windows Utility Manager
  3. Adobe Acrobat Reader
  4. Adobe Acrobat e-Book Reader
