BIOSTAR iDEQ200P nF3 150 SFF Barebone Gallery (5)
Overclocker 7 Oct 2003
Hardware Monitoring in BIOS. The CPU maintains a temperature of around 41 Deg after running loops of 3DMark2001.
CPU FSB can be increased up to 250MHz in 1Mhz stepping
AGP can be locked at 66 or if you wish to overclock it,
you can set it up to 100MHz
CPU Voltage can be increased to the above settings of 1.7%, 3.4%, 5.1% of default voltage.
DDR Voltage can be set to 2.75v, 2.85v and 2.90v
