ASUS P4S800D-E SiS 655TX Mainboard Review (3)
Benchmarking Before we benchmark, we document the FSB the board is running at. Do bear that in mind when comparing results of the boards as a higher FSB usually will impact the benchmarks in one way or another. The ASUS P4S800D-E runs at a default of 200.09MHz. We ran the tests at 200/200. In our test, we run the 3.0 Ghz (P4 800MHZ) processor at 200Mhz FSB and with 2x256M Kingston DDR400 module at, CAS 2, 5-2-2 on the the SIS 655TX, SIS 655FX Ref board and Springdale/Canterwood boards. For stability, we set the voltage to 2.7v for the DDR. On the ASRock P4i45PE (i845PE) & ABIT BH7 (i845PE), we ran it using a single stick of 512M Corsair XMS3500C2 at CAS 2, 5-2-2. PAT is enabled by default on all Canterwood boards.
From the chart, the results are quite promising. The memory benchmark shows a score of 5023/5024 which is higher than most of the dual channel ddr400 boards tested. Furthermore it is running at a default of 200.09 while some boards are slightly higher in FSB at 200.5 or so. Next >>> |
