AOPEN AX4C Max i875 Canterwood Mainboard (6)
Overclocker 21 Apr 2003
In Comanche 4 benchmarks, the performance of the AOPEN board is definitely faster than the i845PE ABIT BH7 by 1.3 fps. The difference between the Canterwood is also with 1fps of difference.
On CodeCreatures Benchmark pro, there is practically not much difference in this benchmark. The difference is merely a difference of 0.1. We re-bench a few times and went back to check if everything is installed properly to ensure possible errors during the tests.
