AOPEN AK79G Max
nForce2 (5)
Benchmarking ZD Content Creation 2002 Content Creation Winstone is a system-level, application-based benchmark that measures a PC's overall performance when running top, Windows-based, 32-bit, content creation applications on Windows 98, Windows 2000, Windows Me, or Windows XP. Content Creation Winstone 2002 uses the following applications:
Following the lead of real users, Content Creation Winstone 2002 keeps multiple applications open at once and switches among those applications. Content Creation Winstone 2002 is a single large test that runs the above applications through a series of scripted activities and returns a single score. Those activities focus on what we call "hot spots," periods of activity that make your PC really work--the times where you're likely to see an hourglass or a progress bar. All boards running in SYNC DDR333 (166/166) otherwise specified. The FSB of the various boards are : AOpen AK79G Max : 167.04Mhz In this test, it came as a surprise to me as ASROCK K7S8X secures the top position in performance in Content Creation Softwares. It can confirmed that the SiS 746 and 746FX boards does perform very well in this category. the AOPEN and EPOX boards scores around 42 points which is 1.5 points slower than the SiS boards. |
