AOPEN AK79G Max nForce2 Gallery (1)
Bluetooth 5 Mar 2003
AOPEN AK79G Max
On March 3rd, AOPEN announced that it will release a number of boards based on nVIDIA's nForce2 chipset. It came as a surprise to me and to everyone. AOPEN has 9 different models which are both ATX and MicroATX. AOPEN AK79G Max is what we have got and it is based on the nForce2 GT+MCP-T chipsets. It features on board video with the capability of GeForce 4MX (8x). It also comes with dual channel DDR266/DDR333/DDR400 for maximum performance. It features other things like nForce Audio Processing Unit (APU), nVIDIA SoundStorm and Dolby Digital Compatible, 10/100Mbps network and integrate 1394 ports. AK79G Max also comes with SerialATA.  AOPEN AK79Max has included some very innovative and unique extra value onto the board. WINBIOS is one such exceptionally new invention which will bring you even more control of your system all from within Windows.
Extra Value
Newly invented features are abundant.
EzClock, it not only allows you to set the voltage and frequency of CPU, AGP, PCI and memory under Windows environment, but also overclock onboard VGA of nVidia Motherboard, which is invented by AOpen exclusively! WinBIOS, is another dedicated invention to make users feel more confident while configuring BIOS settings under Windows environment, plus with multiple-languages support. Small but crucial features that bring excellent user experience such as SilentTek, SilentBIOS, DieHard BIOS, VividBIOS, Dr.Voice II, WinDMI, Open Jukebox and EzRestore are also included for the worldwide users.
About WinBIOS
AOpen developed a new useful WinBIOS utility, which is a Windows-based utility and can be executed exclusively on AOpen motherboards that is compatible with the Windows 2000/XP operating systems. Starting now, you may configure your BIOS parameters whenever you like while found yourself under the Windows environment instead of rebooting and pressing DEL key. The user-friendly traditional BIOS interface designed allows you to adjust/set BIOS parameters with assistance from clear description for each item.
In addition, WinBIOS, has a multi-language interface. There are various widely-used languages provided on our website for your downloading. AOpen "considerate design" also helps to prevent wrong settings caused by misunderstanding of the languages. The only thing you have to do is to visit our official website and download the language pack (few KB size), then double-click on it to activate the support with your native language. After installing language pack, users may simply change the language by pressing F3 key.
With this scalability, either for newly bought motherboard or the latest BIOS version with new function, you don’t have to re-install the whole program again and again. All you have to do is to grab the latest profile from our website, simply double-click on it as well to support the latest version of your BIOS. You don’t have to spend any extra effort to have your motherboard supported by WinBIOS.
