ABIT IC7-G Canterwood 875P Review (1)
Bluetooth
4 June 2003
ABIT IC7-G
The IC7-G is ABIT's Canterwood offering. As we know Canterwood or 875P is the top notch platform aimed at workstations and specifications are similar, it would be a re-run of what it can support or what it can't which is listed in the features below.
Being one of the top company that does overclocking, ABIT IC7-G not only overclocks but brings the best overall performance to the IC7-G. Being the only company that supplies the ABIT Serillel2 bundled with the board, ABIT IC7-G is the only board in its class to allow you to take advantage of Hot-Plug functionality and ATAPI Devices, such as CD-ROM, CD-RW, DVD-ROM, allowing users to experience the advantages of cool, clean cases with all of their IDE devices! With Serillel2 and the SATA 150 RAID 0/1 controller by Silicon Image, only ABIT allows users to connect up to 8 Hard Disks at once!
While most other boards uses other chipsets and not taking advantage of what CSA can offer, ABIT IC7-G incorporates CSA LAN with the Intel® 82547EI Gigabit Ethernet Controller. CSA enables bi-directional Gigabit networking with higher performance and lower latency.
Features
CPU
  • Supports Intel Pentium 4 Socket 478 processors with 800/533/400 MHz FSB
    (400 MHz is for Northwood only)
  • Sports Intel Hyper-Threading Technology
Chipset
  • Intel 875 / ICH5 RAID
  • Support Intel CSA Gigabit LAN
  • Supports Dual Channel DDR 400 with ECC function
  • Supports Performance Acceleration Technology (PAT) function
  • Supports Advanced Configuration and Power Management Interface (ACPI)
Memory
  • Four 184-pin DIMM sockets
  • Supports 4 DIMM Single/Dual Channel DDR 400 memory.(Max. 4GB)
  • Supports configurable ECC function
AGP
  • Accelerated Graphics Port connector supports AGP PRO 8X/4X (0.8V/1.5V)
Dual Serial ATA RAID
  • 2 channel Serial ATA 150MB/s data transfer rate with RAID function (0) via South Bridge
  • 2 channel Serial ATA 150MB/s data transfer rate with RAID function (0/1) via Silicon Image PCI Chip
Audio
  • 6-Channel AC 97 CODEC on board
  • Professional digital audio interface supports 24-bit S/P DIF optical In/Out
System BIOS
  • SoftMenu™ Technology to set CPU parameters
  • Supports Plug-and-Play (PNP)
  • Supports Advanced Configuration Power Interface (ACPI)
  • Supports Desktop Management Interface (DMI)
  • Write-Protect Anti-Virus function by AWARD BIOS
Gigabit LAN
  • On board Intel CSA Gigabit LAN
IEEE 1394
  • Supports IEEE 1394a at 100/200/400 Mb/s transfer rate
Internal I/O Connectors
  • 1 x AGP PRO, 5 x PCI slots
  • 1 x IrDA
  • 1 x Floppy Port supports up to 2.88MB
  • 2 x Ultra DMA 33/66/100 Connectors
  • 4 x Serial ATA 150 Connectors
  • 2 x USB 2.0 headers, 2 x IEEE 1394a header
  • 1 x CD-IN, 1 x AUX-IN
Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 mouse
  • 1 x Printer Port, 1 x COM port
  • 1 x S/PDIF Out connector, 1 x S/PDIF In connector
  • 1 x Audio connectors (Front Speaker, Line-in, Mic-in)
  • 1 x Audio connectors (Center/Sub, Surround Speaker)
  • 2 x USB 2.0, 1 x IEEE 1394a
  • 2 x USB 2.0, 1 x RJ-45 LAN Connector
Miscellaneous
  • ATX form factor
  • Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
