Shuttle SS51G P4
Barebone System Gallery (2) The Internal The box looks very identical the SS50. The major difference is that the heatsink adopts the concept of SS40 where by a heatpipe is used. A fan is mounted at the rear which sucks the hot air. The fan speed is also variable which only spins up at a threshold CPU heat temperature set within the BIOS. The retention mechasnium in the shape of a cross to secure the heatsink to the P4. The manual gives a very good description on how to buckle and unbuckle the retention mechanism. |
