EPoX 8K9A2+ KT400 Mainboard
Review (8)
Benchmarking 3DMark2001SE The well known test for Direct3D with DirectX8.1 installed. The results are very obvious. Again, we see that the ABIT AT7 Max2 has a 100 points gain over the Gigabyte 7vaxp and the Gigabyte leads by around a 100 points over the EPoX. Although it seems a lot, in fact, it is less than 1% of a difference if you get your maths correct. |
