EPoX 8K9A2+ KT400 Mainboard Review  (3)
Overclocker 23 Oct 2002
Memory Benchmarks
SiSoft Sandra 2002
The infamous SiSoft Sandra 2002 is used to test out the memory benchmarks. All the systems are tweak to it's maximum possible settings of CAS 2, 2-2-5.
The chart below compares the memory benchmark scores when we run the boards at various CPU/Memory Freq Ratio at DDR333 at CAS 2, 2-2-5 as indicated in the gallery.
ABIT's AT7 Max2 FSB registers a value of 133.39Mhz on WCPUID. Most manufacturers will "overclock" it to 134.00 so that the benchmarks will look better.
EPOX 8K9A2+ (133.64), Gigabyte 7VAXP (133.9), ABIT AT7Max2 (133.39)
From the results, it can be seen that both KT400 boards performs almost identical in memory performance as both are tweak to the maximum possible settings within BIOS.
