EPoX 8K3A+
Review (4)
Benchmarking We conduct the usual tests on the setup with the following configuration : Test System:
Sisoft Sandra 2001te Benchmarks DDR266 DDR333 Summary AthlonXP1500+ Update : With the new BIOS dtd 25 Mar 2002, memory benchmark scores also increased. Old scores are in brackets. Running at 1T Cmd, 2ns, Depth=8 and we only managed to squeeze a bandwidth of 815/883, but when running the system at ASYNC DDR333 mode, we noticed the benchmarks is increased to 869/951. Hmm, MSI seems to be better off. If you look carefully, KT333 doesn't seem to ourperform some of the KT266A available in terms of memory performance.
FSB EPoX 8K3A+ = 133.64Mhz |
