EPoX 8K3A+
Review (1)
If you have been following our reviews, EPoX 8KHA+ is one of the best selling and performing boards. This time round, they threw in HightPoint HPT372RAID on board which provides ATA-133 RAID. Based on the KT333 chipset, The EPoX 8K3A+ is an improved version of 8KHA+. The Southbridge is VT8233A which supports ATA-133 HD. A 6 channel audio chipset ALC201A is also implemented on board for digital audio. This is probably the one of the few boards that allows Vcore to be adjustable from 1.4v up to a high of 2.2v. Normal mainboard usually stop at a maximum of 1.85v. CPU Ratio is selectable from 6x ~ 15x. DDR voltage is selectable too up to 3.2v. CPU Clock is adjustable from 100 ~ 255Mhz at 1Mhz stepping. During the boot up of the mainboard, the screen which monitors the various temperatures and fan speeds. The BIOS used is dated March 12, 2002. Below are the specifications of the board. The subsequent pages will be the gallery followed by benchmark results including SuperPI, Q3, etc.
