THE
CHIPSET HEATSINK MOD GUIDE
Updated 05/11/02 by Tim B @ OCWorkbench.com
Useful related threads.
http://www.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=get_topic&f=27&t=001975
http://www.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=get_topic&f=27&t=000398
This mod improve the
efficiency of the standard heatsink on the mobo. It helps when trying to
achieve high fsb’s and can improve stability. Note there is no chipset
temperature on the K7S5A, the board has the capacity for 3 but only two are
connected.
By OC_Ripper
It's easy. remove it by twisting the heatsink. The clean the sink and chipset
from all the leftbehinds. Now apply a thin layer of thermal paste (mostely
white). Remove a little bit on the corners (the edges dont need to be glued).
now put a little drop of superglue on the corners of the chipset. press the
heatsink onto it, within a few seconds you wont be able to get it back off. and
voila. you might consider afterwards of putting a fan ontop of the heatsink.
