ASUS P4S8X SIS 648 Review (11)
Overclocker 23 Aug 2002
The ASUS P4S8X is definitely one of the most innovative boards we tested in our labs. With a strong feature set like USB 2.0, AGP 8x, Serial ATA, RAID and 6 channel audio, 1394 (optional). With these new features, it definitely brings the overall I/O performance to another level.
In our tests, the performance of this board is pretty good if you were to run in the official DDR333 mode but it lost to the SiS 648 ref board and the Shuttle AS45GTR. This could be due to the ram timings that are set within the BIOS. At the unofficial DDR400, we are unable to complete most of the tests and it is very unstable even with the Corsair DDR400 CAS 2.5 module set to run in SPD mode.
Overclocking wise, we managed to overclock up to 150Mhz FSB using our P4 2.4B processor. If you are into overclocking, the FSB is only selectable up to 166Mhz FSB. I suppose this will change in the near future. Some users were asking me whether there are any FIX PCI mode, well the answer is No. Thus you can't set FSB above 133 and run the PCI/AGP at 33/66 FIX. Vcore/CPU/AGP voltages are adjustable.
The board layout really needs to be improved. The AGP Slot's retention clip is too close to the DIMM slots and makes it quite difficult to remove DDR if the AGP card is installed.
Documentation is concise and the multi-language BIOS is definitely a welcomed move. Installation is very straightforward, there is ample space around the CPU. Most of the heatsinks should have no problems fitting it. Bundled with the package is a free copy of the intervideo WinCinema
TCC Q285 Tri band Handphone
Leadtek WinFast TV2000XP TV Tuner card
Albatron KX400+ PRO
Gigabyte ATi Radeon 8500 128M
NOKIA 7650 Handphone
Shuttle SS51G SIS651 SFF Box PC
ECS L7VMM KM266
Shuttle AS45GTR SiS 648
Gigabyte ATi AP128DG-H Radeon 8500 128MB
Nokia
7650
Preview
Lite-On Overclocking & Media Guide
Chaintech 7VJL KT333 Gallery
ECS Xabre AG400
ASUS P4T533 RIMM4200
ABIT
 MediaXP
ASUS Dual Channel DDR Preview
ASUS P4S8X SiS 648 Preview
More reviews at http://www.ocworkbench.com/hardware/reviews.htm
Below, we list down some pros and cons of this board :
Pros:
  • ATA-133 RAID and S-ATA RAID supported by Promise chipset
  • Serial ATA
  • CPU ratio, FSB (1mhz), Vcore voltages adjustable
  • 6 channel audio
  • USB 2.0
  • 1394
  • AGP 8x
Cons:
  • 3 DIMM slots only
  • Board layout
  • DDR400 support
Here are my ratings out of 5 stars.
 Category
Score
 Performance
 Features
 Ease Of Installation
 Overclocking
 Documentation
Overall Rating :
4.4 / 5
